Old 11-07-2012, 04:06 PM   #29 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
scored 4) 4x8 in 1mi from my apt. thats about all i could roll up and cram into the back seat of the fiesta!! was done in 20mins from leaving to gold rush around 9pm. Then scored those foam laminated poster boards from work 23) 2'x3' and 7) 2'x2'. So i have ALLOT of template/scrap material to work with!! Gonna look for more signs on the way home tonight.
Side note: Some of your local farmers just on the outskirts of major cities may have their signs up longer than usual... Might check them out if you haven't they usually have 4-8 signs just alone 1 field.
Good Luck every1!
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
