Grandmother used to own a 93 Justy (bought new) and was driven like Granny going to church. It died an unceremonious death (1997) when it spun a rod bearing (from what I recall) then put a hole in the side of the engine... at 40000kms. The rubberband transmission had been replaced once, and it ate fuel injectors. Always had regular maintenance but was just one little POS.
The 4wd system worked good but the rest of the cars flaws greatly outweigh that!
If you're in Nebraska and the wind stops or you see a tree, pull over immediately and take a nap. You're having road hallucinations.
