Now with the Vibe I was cautious and did 1mL per gallon or 10mL per tank usually. I saw a jump in mileage and my log proves it.
Then I began reading other sites etc ... and saw the 1oz per 10 gallon and thought that was way to much and/ or expected tremendous results for myself. Well 1oz got gains (30mL), im currently playing with 2 oz and I must say I do not see much improvement, yet ...
However I'm thinking that some one messed up the conversion somewhere along the way ... Because I am getting better results with 1oz - 30mL than 2oz - 60mL
So at least with my adaptations my Vibe saw the best gains on 1oz per 10 gallon and the same holds true with the xB we tried it on it saw the best numbers with 1oz per 10 gallons. I wont even waste 3oz per 10 gallon, because I am sure the results will get worse, unscientifically ... lol
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
