Originally Posted by darcane
Hold on here. The one caveat with the Ultragauge (and Scan Gauge) is that it won't accurately report fuel economy in Lean Burn mode. I believe these gauges base mpgs off air flow, not fuel flow, so they are way off when it runs lean.
This is my thread trying to figure out how far off it is:
http://ecomodder.com/forum/showthrea...mpg-23441.html
That is correct. To read mpg on an HX (or VX) you need an MPGuino or other gauge that reads fuel injector pulses. See the Instrumentation forum here. It has a MPGuino sub-forum, you can buy one from threads there. My 'guino is usually accurate within .1 gallon.
