Old 11-10-2012, 04:14 PM   #276 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Here is my two cents.
1. must be using a scangauge or some system BESIDES filling up to determine mpg.
2. Assuming 1, then set cruise at a fixed mph and record results from scangauge.
a.) temp, rpm, ign etc
3. Where it is flat for a couple hundred miles, record then stop, clear gauge, put magnets on, and record.
4. record in the same place on the return trip..
5. BEFORE the trip, set up a basis for your car, running on a flat area to establish a baseline.
Now, if you decide not to do this, don't try to present to us that the magnets 'worked'.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
