Old 11-12-2012, 12:50 PM   #30 (permalink)
turbovr41991
Civic CX/HX - '97 Honda Civic CX/HX
90 day: 63.77 mpg (US)
How is the tuning with the HX coming along? Are you having any success using the stock P2N ecu? If a P28 ecu would be used would there be a convenient way to monitor parameters like engine load, throttle position sensor, and a lean burn indicator? I currently use a scan gauge 2 which connects using the OBD2 port to monitor these areas to maintain maximum fuel economy. Wondering if there is a jumper harness for the OBD2 port or if anything can be done to use the Scan gauge or ultra gauge or if there is other options to view this data. Thanks!
