Old 11-13-2012, 05:00 PM   #3 (permalink)
WesternStarSCR
Busting Knuckles Often
Blue Maxx - '04 Chevrolet Malibu Maxx LT
Team Chevy
90 day: 26.96 mpg (US)
Tink's Van - '08 Chrysler Town & Country Touring
90 day: 19.09 mpg (US)
2004 5 Speed Goldrolla - '04 Toyota Corolla CE
90 day: 36.3 mpg (US)
Thanks you
I'll be following this project.
I'd also like to mention my "bad" experience with valve stem extensions for others' interest.
I bought a set of extensions for the Firefly (Metro) when I glued flat plastic over the openings in the OEM wheel covers and needed a longer stem.
A day or 2 later I had four flat (or very low) tires!
When tightened down snugly, apparently the extensions put just enough pressure on the original valves to let a bit of air leak past. Backing the extensions off slightly fixed the problem.
I put the valve extensions on over the weekend. I will check my PSI when I get home from work... had not thought of that!
