To avoid balancing issues you could use Dyna Beeds or Counteract balance beeds. Oriely's can get the counteract the next day usually, I buy a pound($30) and put 1/4 in each wheel when changing tires or thru the valve stem. Buy it once and reuse it. With TPS seems to take a little more 5-6 onces or leave a weight opposite the valve stem and can't install thru the valve stem.
