Old 11-14-2012, 01:20 AM   #31 (permalink)
SpeedyCorky
also races Sportbikes!!!
SpeedyCorky's Avatar
Mo' Mon-nay! - '00 Honda Civic HX
90 day: 52.26 mpg (US)
Carbon Silver - '06 Honda Insight
90 day: 82.2 mpg (US)
yeah get the basic maintenance done first. i'm past that point thankfully. i expect the MPG differences to be dramatic between the two.... as the FED ecu it is so easy to get it in, and keep it in lean burn - so automatically it would win - at least for speeds above 65mph that is. (since lean burn isnt really reliable below 65mph). even under the best circumstances, i couldnt ever get my CA ecu to really get into, and stay into lean burn. where as the FED ecu i can literally control it with how much i push on the pedal, a noob could do it. there is no fight, there is no battle to get into lean burn.
with the FED ecu, I can be flooring it up a hill, then quickly let off back to very low throttle for just a moment or two (14% TPS) - drop into lean burn, almost as easily as flipping a switch - then gradually reapply throttle to as much as 90% engine load and 32% TPS... its pretty sweet when its all working right. try that on a CA ecu
i'm very curious as to which is better for speeds like 58 to 60mph.
2000 Honda Civic HX with mild aero mods
2006 Honda Insight
MIMA, FAS, no passenger sideview mirror, race style drivers mirror, front and rear underbody aero, temporary front air dam
