Old 11-15-2012, 07:51 PM   #11 (permalink)
Rusty94cx
Rusty crusty trusty - '94 Honda Civic Cx
90 day: 36.13 mpg (US)
Vx - '92 Honda Civic Vx
90 day: 49.97 mpg (US)
Yes you can't tune a 07 but you can burn those maps onto anyother ecu ie a p28 and run it like that. The p28 he was running if that's what he was doing also doesn't support 3 stage v Tec that's where the tune comes into play. If you drive it sensibly you could have it runn right and possibly use less fuel. Shorter pulse width on injectors. And you could widen the lean burn perameters. You can chip a07 ecu it just gets screwy for some reason. And I'm sure were talking about a small turbo to spool quickly and little boost possibly 5 psi?
