I know that the "Zetec 2.0" in the focus is the same as the Mazda 2.0 and I believe they haven't changed that engine since the early 90's.
Pfft, typical Ford!
FWIW, I've switched over two Chevy four bangers to full synthetic after running an engine flush. One engine I switched at 70Kmi, the other at 88Kmi. Both engines are still in service today with zero ill effects. I would also advise you to stay away from high mileage formulas.
