8lb wheels(vs.17lb stock steelies), light weight brakes, can you say carbon fiber? body-seats(11.5lb vs. 35lb stock)-panels-components..., light weight engine goodies, suspension, poly-something-lexan window replacement the door-qtr-rear is good for 72lbs...if i remember correctly. im still trying to figure out the adverse effects of a 7lb flywheel(21lb stock?)(on just the seats,glass,wheels,flywheel and brakes...im around 165-200lb savings...w/o body/major engine) the 88crx hf is around 1819lbs stock w/o AC
