Old 11-19-2012, 08:57 AM   #19 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
looking at it now with the template, doesnt look bad as i thought. I didnt have much time to look before with my kamm response. Maybe a few inch extention to your spoiler could make a small improvement.
Agreed with others on buttoning up the front, and front/rear belly pans. haven't seen what it looks like under the boot area, but if like other hondas i've seen, its a parachute. still not as big as mine.
With your CL lowered, i assume you've also made a roll bar change, and aligned everything properly. How is your chamber?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
