Old 11-22-2012, 02:16 PM   #18 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
30-35mpg
Drove to Austin from San Antonio on hwy 35 to have Thanksgiving w/ my daughter.
Thru a couple of 'relatively' flat stretches I ran the cruise at a set speed. It was 76degrees outside. low humidity. 40 psi. no mods.
here were the results:
30.1mpg....60mph....2180rpm....17 miles....193watertemp.....700ft
35.1mpg....50mph...1825rpm...15 miles......190warertemp.....650ft
I'll run the same stretches going home on friday and post up.
Also got my first tank to tank fill. (well 1/2 a tank) went back and forth to work about 29 miles 90% freeway. stop and go about 1/3 of trip. And one trip at 70-75mph
The kia trip computer said 25.0mpg, the actually fill up was 23.65 over 198 miles
Need to run a couple of 350-400 mill tanks to get a better feel.
But gas in San Antonio was 3.09 -usually 3.18 - (less 12 cents HEB grocery store card) and I didint want to pass that up!!
I think that the data tells me 2 things.
1. need a lower and probably up grille block to warm up faster. ran the 50 mph AFTER the 60 mph and the water temp dropped (190 was the high. it was 186-188 at times) The 193 for the 60 is also pretty low.
2. The 70 series tires seem a logical next step. Lower rpms will help. maybe I can get down to 1975rpm at 60 mph!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
