Thread: GEET Reactor
Old 11-25-2012, 12:05 AM   #93 (permalink)
RustyLugNut
I have built vapor carbs.
Originally Posted by JRMichler View Post
Rusty, you are up against the fact that most people on this site KNOW that the GEET reactor is bogus. However, what is common knowledge is sometimes wrong. If you feel that the GEET reactor, or a similar fuel conditioning system, will get better gas mileage, then build one.
This is, after all, EcoMODDER.com. The GEET reactor is certainly simple enough that any normal person can build one. The patent has all the necessary information.
We would be happy to help with details, such as materials and techniques to stand up to the temperatures and pressures. We ask only that you tell us what you are doing and test it according to the procedures in this thread: http://ecomodder.com/forum/showthrea...ery-11445.html. Then report the results, whether good or bad.
And I have helped in building a GEET and tested it on a single cylinder genset and a carbureted 3 cylinder Metro. I am intimate with the problems inherent with the GEET as well as the possible ways it could be used beneficially.
And certainly, I will try to "spill the beans" if we can produce anything of value to this forum and if my boss doesn't tell me that the information infringes on company trade secrets ( I work for a R&D company that deals with emissions, so economy shouldn't be a problem right?).
Remember that the fuel processor (FP) is to be driven off the exhaust and the heat is variable to the extent the FP will not work well outside a narrow range. This means we will have to design the system to work when most beneficial to economy - light loads and cruising.
