Originally Posted by bschloop
I agree that plastic wrap releases the composite better, but how do you get the Glad wrap to stick to the foam? When I tried to, it didn't want to stay put while I was placing the next piece. for the foil I just spray a small amount of general purpose spray adhesive on the foil then place it over the plug.
I don't mind too much if the foil doesn't all come off, since it's on the inside where no one will see it.
I did not try to stick the GladWrap to the foam and then lay glass on top of that.
What I did do is lay the glass on top of the foam, and then lay the GladWrap on top of that and put mechanical force on the layup for better adhesion.
If I understand your application correctly, you are attempting to use the Glad Wrap as a PVA of sorts?
Jim.
