you should have been able to test the bearings when you changed the axle shafts. by rotating them back and forth with your fingers . if you didnt its not to late . raise the wheels of the ground , chock or ebrake the rear wheels , take the car out of gear and rotate the wheels . you should be able to id which side the problem is on push pull and load the wheel if you need to . keep us posted
