Originally Posted by straight5
That would be really good - if only it had a reset.
weird, I bought one a few years ago and there was a reset switch too.
In fact I just pulled it out and am looking at it and yes mine has a reset switch.
Just looked at the link I gave you and the instructions for that one shows a 'remove this red wire' where as on my kit that removed red wire, and the other red wire are shorted together for a few seconds to reset counter to '00'.
Wonder why the MPJA version doesn't use that function?
Edit: I found out why - it does not work! The wiring does not match the product. Both of the red wires do the same thing - AC power input.
However on that side of the board is C2, a 220uF cap. Short this out momentarily and the count goes back to '00'. Just tried it and it works.
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
http://www.dschmidt.com/MPGuinoJBD.html
