Old 11-26-2012, 01:18 PM   #8 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
My ScanGauge typically reads 0.1 - 0.2 volts low compared to a voltmeter reading at the battery itself.
You say you checked the voltage via the ScanGauge with the car "off". But was the ignition turned to "on" or "accessory"? If so, that will drop battery voltage some (compared to not having the ignition key in).
You can check voltage via the SG without the ignition key by waking it up -- pressing a button -- and calling up voltage gauge.
