Old 11-26-2012, 01:32 PM   #28 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Window problems are usually due to the tracks getting out of adjustment. But you're probably familiar with that.
If not -
Remove door panel. One track at each end of window. Each track has a adjustment near bottom. My recollection is one is fore-and-aft, the other adjuster is in and out. So between the two, you can match the tracks to the window. I had one work loose and need attention again after about a year or two.
Coast long and prosper.
The Following User Says Thank You to brucepick For This Useful Post:
Sven7 (11-26-2012)
