Originally Posted by Sven7
1. Plasti-dip the back of the block
2. Drill 4 eye hooks into it at the corners
3. Pull a zip tie through each pair of eye hooks, tightening them around the back of the grille slats.
$10, 20 minutes.
True, but that might not meet the "pretty" standard marked-out as a priority in the OP. I think the weather stripping is a good idea. Then you might also glass onto the back some sort of hooking or strapping hardware, cushioned so as not to scratch the OEM surfaces.
