Old 11-27-2012, 04:35 PM   #34 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
you cant id it with a number have to get it on the highway. look for around 2k rpms at 60-65 mph. if you are up toward 3k rpms at 60-65 then its not a cx/vx trans. (while in 5th)
if it has the correct ecu and everything is done properly you should be seeing 40mpg tanks in no time. winter takes a toll but its doable.
