Old 11-30-2012, 09:02 PM   #7 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I replaced the plugs today and put a bottle of some Lucas junk in a fresh tank. On my way home from work I didn't notice the hesitation but it's intermittent so I'm not certain it's fixed yet. I have a new factory O2 sensor on its way.
Was a bit sad when I opened the hood and noticed some oil on the bottom of my A/C high pressure line and also around my power steering pump - those definitely weren't there a few weeks ago. Although the power steering pump will probably be an easy fix, air conditioning never is.
Originally Posted by nbleak21 View Post
Plug Gapping back to spec or as stated above, or advancing the timing a couple degrees would be my first attempts. Price = Free!
My timing is already advanced, or at least I think it is. I bought a timing light last year and I was actually unable to see the timing marks at all (though I've never timed a vehicle before). One of the symptoms of advanced timing on my engine is a high rolling idle and I ended up adjusting it until the idle was where it ought to be when rolling in neutral, and then advanced it just a bit from there. I don't get any predetonation even with it fully advanced though.
^ I doubt my timing is the (direct) cause of my recent troubles though as it has been fine for the better part of a year and only recently developed these problems.
