Originally Posted by nbleak21
Did you jump the diagnostics terminal in order to establish baseline ignition timing? This is a commonly overlooked part of the processes that will net the results stated.
Adding to nbleak21's comment above, are you sure the car was warmed up when you checked for timing marks. Being completely unable to find the marks suggests a problem with the timing belt, the engine temp, your placement of the timing light, or that the timing is too far off. Also, there is a normal oscillation of the timing a couple degrees plus or minus the stock setting, so if the marks momentarily disappear, that might be why.
