Old 12-03-2012, 01:54 PM   #1 (permalink)
MickZ
Found an HF! Kinda rough though; need opinions.
I found a not-so-pretty 89 HF equipped with non-working A/C. The owner says it burns a little blue smoke when say, you're coasting at highway speed, then get back on the gas--it'll throw a little blue smoke out. It also leaks some oil from the drain plug of the oil pan, so not sure if it's a stripped pan hole or what. It has 280,xxx miles and the owner says it still gets the great HF gas mileage. I got him down to $1,050--I'd like to know your guys' thoughts on if this's a sound buy for the money, or if I should keep searching.
