Originally Posted by sbestca
Hmm, about winter, sad thing about P&G is there is so little load on the engine I lose engine temperature. I worry about it getting cold enough to bring on enrichment. Grill blocking does not seem to be helping and I don't really want to block the rad itself. Usual summer position for temp gauge is 1/2. Winter has been 1/3 at 100kph. P&G seems to have it below 1/4 at 80kph max and -5c temps. Fuel mileage results not especially good but overall cold temps and snow have put a real kicking into any results.
Steve
A ScanGauge will show engine coolant temp digitally; I think UltraGauge will also show it. With that information, you can increase your grill blocking and other engine bay sealing safely. You need more information than what you get from a simple needle gauge.
You may need an engine bay belly pan or hood insulation to get engine temperature up where you want it.
