Old 12-07-2012, 04:10 AM   #55 (permalink)
ctgottapee
the old boat - '93 Cadillac Deville *removed/modified
90 day: 24.2 mpg (US)
Originally Posted by Dan9 View Post
this is an interesting thread, indeed. So many cool ideas!! I'd like to design a 2-radiator system to plumb into my Subaru when the original rad would need replacing. Summers run hot but winters, so hard to get up to and keep operating temp high. I did a cardboard upper grille block, this year it will be FRP. And I have no hood insulation, I may DIY some up.
A higher temp thermostat would solve the same purpose as two radiators, and it would be partially open a mid range temps and turn the large radiator into a small one.
The only exception is your engine must be able to handle the rise to that temperature and/or your cooling system respond quick enough when it reaches that peak that the total temp peak doesn't go higher than what the engine can handle.
An adjustable grill block would probably be necessary for many who run one.
