Old 12-07-2012, 10:07 PM   #11 (permalink)
jime57
OurInsight - '06 Honda Insight
Originally Posted by AeroModder View Post
If you can also build some ducting to direct the air into the radiator instead of allowing it to spill around it, that will allow you to have an even smaller grille opening.
Very true! On my Insight, I keep the coolant temp under control in winter with only 3x6" grill block opening by carefully ducting ALL cooling air through the radiator. But, one caution, you MUST carefully monitor the coolant temp at all times. Try to design grill blocks which can be removed easily if you get a hot day
You probably have cruise control. If you have a flat section of road, you are well positioned to do relatively easy A-B-A testing and get your own personal answer. My guess is it is of considerable value. Has been on all my cars.
The Following User Says Thank You to jime57 For This Useful Post:
mcrews (12-07-2012)
