Thread: Hood Insulator
Old 12-10-2012, 06:08 AM   #14 (permalink)
ctgottapee
the old boat - '93 Cadillac Deville *removed/modified
90 day: 24.2 mpg (US)
Originally Posted by WesternStarSCR View Post
I just saw a How It's Made episode on Roxul brand of insulation, made from 'rock wool'. It can handle high heat and is water proof as well. Anyone try that, as it seems if it strategically secured under the hood, it has great heat retaining and sound deadening properties. I have no clue on cost or availability but they melt slag, coke and salt rock to melt it and spin it into fibers.
Roxul is similar in insulating value to fiberglass bats or loose cellulose.
It isn't water proof, but it doesn't absorb water, ie you can get it wet but it will naturally dry.
It is not as widely available in the US as the 'pink panther' and his fiber glass bats has the markets cornered. It doesn't traditionally come cut in sizes that would go under the hood easily, normally for a stud bay so it would be too thick and you'd have to find a way to keep a bunch of rolls together, but it does cut so its possible.
It's cost is usually higher but in the same ballpark. Being a waste product, its all about market and volume really. It's mostly use in commercial building where fire codes make it more valuable.
It doesn't insulate or sound absorb any better than other things, and some items like foam insulate much better.
The Following User Says Thank You to ctgottapee For This Useful Post:
WesternStarSCR (12-10-2012)
