Swap you instrument clusters they are easy to do possibly the spedo is off on one more than the other unless all this has been gps verified. The only taller gears are the hf final drive and the that is a cable trans not a hydro. The final drive can be installed but that's probably not the case. Most likely speedos off. I'm at 75 80 at about 2100 in the vx. Not sure with the cx no tach. Also are all tires and wheels the exact same size?
