Old 12-11-2012, 09:34 PM   #41 (permalink)
RatherDashing
Originally Posted by Rusty94cx View Post
I can't tell if that's you giving it gas or the car. Does it do that also when it's warmed up? I noticed that it's bone cold on the temp gauge. Check the vacuum get a gauge. It will tell you tons!!!!
Thats me giving it gas.its been warming up idle for bout 10 minutes.temp gauge generally stays pretty low but definetely works.
going to definetely attempt to clean the egr valve out tommorrow see if that helps at all.did clean out the tubing from the intake to head of engine.(dont know what thats called) still having same issues
I've never installed a vacuum gauge or really ever used one before. Is it fairly simple to install?
this is one I'm looking at now. looks like it would be decent enough to use? or any other suggestions.
http://www.ebay.com/itm/JDM-Sport-UN...d62a3c&vxp=mtr
