Originally Posted by Rusty94cx
Its the one right in the middle of the pic. At the very bottom is the drain. Looks like you need an axle seal. Slinging and wet. I need both of mine as well. Use some brake cleaner clean it down short drive then inspect. Go to Hondahookups download the fsm for usdm 92-95. I'll answer any and every question. As for the temp gauge you should readore than that at idle it will take forever to rise. Check the coolant level and possibly replace themostat.
the radiator leaks a little at the very bottom i havent had the chance to check it out yet. the temp gauge starts out low and rises up not too bad. im pretty sure it still works. but thanks on the axle seal idea.is it the axle shaft seal? ima definetely check out fixing that sometime in the near future.then the radiator. i cleaned out the egr valve today and replaced the gasket on it as well. i need to find another bolt for the egr valve only one of the 2 bolts is bolting it on at the moment.
