Old 12-14-2012, 10:13 PM   #12 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
I went to the link for the LED 1157 bulbs in the first post here. The seller - and I consider SuperBrightLEDs.com one of the leading sources in that field - says:
"The load resistor built into CAN bus bulbs are not intended to fix turn signal related issues, such as hyperflashing."
Sorry to say, I think that tells us right there - this bulb does not solve that problem. But take heart, LED replacement of the turn signals could be worthwhile. Read on.
The bulbs are designed to work with the European CAN system, whatever that system may require of the bulbs. I did some quick googling and didn't yet find an explanation of what that is.
We owned 1980's and early '90's Volvos for many years, that had a bulb failure detection circuit. I'm sure it was not the modern CAN system, however it was so sensitive that it would indicate a bulb failure if you had two bulbs of different ages (which I've seen can cause maybe a 10% resistance change) or even from different batches. It looked for differences in the current flowing in the left vs right side circuits.
Anyway - - -
I understand a bit about the blinker's need for resistance in the bulb. Here's my take, especially with regard to our interest I reducing power demands.
An LED version of the 1157 bulb - or for similar dual filament bulbs made to serve as brake and running lights - needs a resistor added to the blinker circuit, so the LED bulb will appear as a regular one to the flasher relay. You wire the resistor in parallel with the bulb, so the resistance of the combination is reduced. And it's power consumption (watts) is now essentially equal to a standard bulb. If it were not nearly identical to a standard bulb, the flasher would be too fast or too slow.
Get their approx $25 bulb. Thats what i got for my brake lights (but they were the other base connector type, you need 1157 for fronts). You will only be wiring the resistor for the turn signal. Not for the running light circuit.
So the running light will give you all the power savings you should get by using an LED bulb. In my view that's what counts, because they stay on when you drive with headlights. The flashing part will consume power like a regular bulb but its not such a big problem. It's only on for a short time, and even then is off half of that time.
That's why I'd consider doing the swap if cost and time availability aren't an issue.
Somewhere (on the SuperBrightLEDs site?) I saw a writeup of what resistor to use. You would need one for left side and one for right. It mght benefit from a soldered connection because the whole reason for the resistor is to control (reduce) resistance. You don't want corrosion in a crimp connector or some such issue to mess it up later.
Coast long and prosper.
The Following User Says Thank You to brucepick For This Useful Post:
California98Civic (12-14-2012)
