Originally Posted by California98Civic
It's an ordinary bolt, counter clockwise, or "lefty," will loosen it. If oil comes out when you open it, then it's full. If none comes out and you add a little until oil does spill out, then you'll know it is full.
Yep ^! The drain plug takes a standard size Honda oil crush washer while the fill plug is a little bigger.
