Looked right on to the pic.i got the bolt off and fluid was comin out.i stuck finger inthere and cudnt feel much below the bolt. So slowly filled it up with all i got that will work which was sae 5w-30 oil. Still making grinding noise of course.
looked all underneath look a lot of pics.radiator is leaking sumwhere on bottom im just gunna replace it.found another bolt for the iacv.took that off and rebolts it in still idling wierd.my guess is its idling wierd from the radiators loss of pressure maybe?
I looked at the pcv piping and everything seemes alright my guess is the hesitation has to be from the wires.their duralast wires and i hate duralast.i had to re-replace them a few months on previous car.im gunna get the ngk plugs and wires at some point as well.
As for the axle shaft seal and throwout bearing i think i might have a trans shop nearby replace them if he doesnt quote too bad.usually they arnt too pricey at all.
