Old 12-18-2012, 04:22 AM   #75 (permalink)
RatherDashing
Never heard of the air bleed screw before im guna definitely check it out tommorrow.the radiator for sure i am going to replace this paycheck.the cap is just warm after driving and it always is leakn a little when parked iv noticed. I cant find the source of the leak on the bottom so im going to just replace it.40$replacement i wont complain
this is the leak im looking at
The biggest thing eatn up the mpg is just when shifting and letting out of gear majority of the time the rpms stick.or rise up a little then slowly drop.my 89 crx did the same thing but i cud never get the iacv off.i replaced the wires on it with performance wires and i think the problem mostly went away.i literally sold it right after i replaced them because at low rpms it was chugging and misfiring so bad but never throwing any codes. Im getn that same chugn feeling from the vx now just lighter feeling.im wonderimg if replaceing the wires wud fix it. but iv never read plug wires causing that symptom before
