Old 12-19-2012, 12:21 AM   #80 (permalink)
RatherDashing
Originally Posted by 1carnut View Post
My vote on the idle issue is the IACV. I had an idle issue with my 94 (not quite as severe as yours) and cleaning the IACV helped but did not cure the issue. I also checked vacuum and replaced the PCV to eliminate those. Finally, I swapped the IACV with another (used) one and it took care of the issue. My idle would kind of "stick" like yours is doing before settling down.
I took out the iacv and spray carb cleaner all through it already.it seemed to be a lil ok after that but started up again later.on my previous 89 crx dx there was a spare iacv with it im not sure if it is also compatible but i might be able to get ahold of it.if not ill just buy a new one later
