Originally Posted by RustyLugNut
Let's have an Ecomodder meet where HHO aficionados as well as other Modders meet for a weekend where they are tested and timed over a closed loop. GPS distance and fuel is measured via weight. Our own mini Xprize get-together if you will. And we can run it in an orderly fashion.
Organizing MPG competitions happens all the time ... over and over again around the U.S. .... that part of the Ecomodder side is easy ... I suspect you will find it much much harder to get the HHO aficionados out there to compete head to head... or the money shot ... let other people run the test HHO vehicle on that same closed loop controlled course both with and without the HHO system enabled.
I'd be all in favor of the concept of the event quantification ... but I have my doubts about how successful you will be at getting it all organized ... but ... best of luck to you ...
Be sure to post up a thread of the details of when and where and such , once you've managed to pull it together.
