so i cleaned out the iacv again today.and forgot to mention that its got two bolts that bolts it on and iv had it bolted on by one bolt. i had another bolt that was threaded all the way thru holding it in as well. i noticed that 2 filter holes might be off by just a hairline.im hoping this is the problem with the idle because i sprayed the iacv again good and it still looked clean. hoping the honda dealership has one available
