Old 06-14-2008, 12:20 AM   #171 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
Car looks good in tall grass if the grass was cut then then you could tell the bottom of the bumpers are 12 inches off the ground.
driving it around today one minor problem became totally obvious. The rear inner fenders are way to small to clear the tires. So that gave me an excuse to play with a plasma cutter again.
I could redo the garbage cans and make them fit but I need this car on the road by next weekend so I can make it to the shows. The fastest way to do it is to use stock inner fenders and just beat them out a bit bigger then stick them in. I can glue the joints up watertight later.
