Old 06-13-2008, 11:20 PM   #171 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
Car looks good in tall grass if the grass was cut then then you could tell the bottom of the bumpers are 12 inches off the ground.
driving it around today one minor problem became totally obvious. The rear inner fenders are way to small to clear the tires. So that gave me an excuse to play with a plasma cutter again.
I could redo the garbage cans and make them fit but I need this car on the road by next weekend so I can make it to the shows. The fastest way to do it is to use stock inner fenders and just beat them out a bit bigger then stick them in. I can glue the joints up watertight later.
Old 06-14-2008, 12:12 AM   #172 (permalink)
TheDon's Avatar
Pepper - '87 Mercedes Benz 300D
90 day: 30.42 mpg (US)
Originally Posted by zjrog View Post
OK... I know most folks just pull out the blue flame wrench to cut springs. Still going to be stiff though. I looked last night for the coilover conversions and can't find what I was looking for. But you could do a universal air ride kit for struts from http://www.suicidedoors.com...
you never want to use any form of flame to cut springs. Spring metal is very finiky about heat. It's like tool steel or something, I can't remember its late. But what you want to do is use a cut off wheel since it will screw up the metal composition.
Old 06-14-2008, 09:03 AM   #173 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Jeep Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Dodge Neon SE
90 day: 33.46 mpg (US)
S'Crew - '02 Ford F150 Supercrew XLT
90 day: 16.4 mpg (US)
Ranger - '90 Ford Ranger
Last 3: 28.02 mpg (US)
Not the Jeep - '03 Dodge Neon SE
90 day: 34.11 mpg (US)
I originally thought he was going to flame cut the springs, but he has the better idea. Best idea is custom springs or adjustable ride height of some sort. I think flame cutting the springs is about as safe as eating a bag of Doritos while standing in the middle of the freeway rush hour traffic....
When it comes to Heroes, RENEGADES are mine!
Old 06-14-2008, 11:37 AM   #174 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
I found these for you;
Intrax Front Rear Coil Springs - Phosphate Coated Powder Coat
1989-1997 Geo Metro"INTRAX LOWERING SPRING KIT -- Front 1.7 And Rear 1.5 Drop, These Springs Are Cold Wound To The Most Exacting Standards, Stress Relieved And Shot Peened To Remove Surface Imperfections Extending Service Life Up To 200% Or More, Springs Are Also Phosphate Coated For Corrosion Resistance And Powder Coated To Ensure A Lifetime Of Outstanding Looks, With Manufacturer's Limited Lifetime Warranty, Requires Camber Kit Front Part Number 99.9.007"
Fits: MS2/6 MR2/3/5/6.
Finish: Phosphate Coated Powder Coat
Availability: In Stock
1989-1997 Geo Metro I20251010 $299.00
@ www.thepartsbin.com
I'll keep looking for your sideskirts too ...
And Viola ... Razzi makes a nice body kit for this car, but they will sell the side skirts seperately.. Enjoy
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 06-19-2008, 03:16 PM   #175 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
sooooooo.... did the car ever get fully completed?
Old 06-19-2008, 09:29 PM   #176 (permalink)
nut
Coyote X's Avatar
I have been working on the car but haven't had much time lately and the stuff I have done is just little detail junk
Here is my drivers side rear view mirror.
It is just primered and needs a bit of finish sanding and spot putty to smooth it out but I put it on the car so everyone could see how it looks. I will work on the passenger side next and paint them both at the same time I guess.
I finally found a good set of side skirts and they will be here tuesday. So tues I will start building the belly pan and a little bit of framing that needs done like the seat brackets. But mainly right now I am just doing detail stuff and trying to piece together all the best parts I have so the car looks nice for the car show on the 4th.
Old 06-22-2008, 11:42 PM   #177 (permalink)
nut
Coyote X's Avatar
The end of the line for the hatchback body.....
Took three people to pick it up and set it on the trailer. Mainly just because it was big enough to be hard to manage for two. We turned it up on its side before loading it to get the rear suspension off it and the rear was almost rusted in two. I knew the front end was pretty bad but i had no idea the back end was worse. The floor was totally separated from the sides and only held in place by the firewall and half of the rear was still attached.
The only part left on the body was the rear view mirror there wasn't a single bolt left in it other than that I think.
Old 06-23-2008, 08:10 AM   #178 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Not going to remove the windshield? Couldn't you sell that used, or use it somehow? Or does it have a crack in it prohibiting that? or is that the only piece hoding the metro together?
American by right
Ecomodder by choice
Hypermiler by necessity
Old 06-23-2008, 11:41 AM   #179 (permalink)
nut
Coyote X's Avatar
The windshield is cracked. I broke it trying to get it out
Old 06-24-2008, 10:37 PM   #180 (permalink)
nut
Coyote X's Avatar
Had other stuff that needed doing the last couple of days so not much time for the car. I did manage to get it about 3ft in the air though
Takes nothing to pick the car up since any frame member can support the entire car. I could hook to the back bumper and lift the whole back end the same as I did the front. I could also hook to the side bars inside the doors to lift the side of the car up. If it was possible to get to the bar in the dashboard I bet it is probably near the center of gravity and I could lift the entire car at once
Also I have some side skirts to play with now and I just picked up four 4x8 sheets of coroplast for the belly pan. So it looks like the last of the big work for the car should be done this week. One thing I was thinking though is how does everyone make or mark out jacking points on their underbelly so they can jack the car up in the future. I really don't want to have to drag the engine hoist out every time I need to take a tire off
MPG Gauge for the Geo Metro XFi Wayneburg General Efficiency Discussion 2 03-10-2011 06:48 PM
Geo Metro Conversion - Standard to XFI SirKeats EcoModding Central 16 10-22-2010 01:44 PM
1995 Geo Metro DRL disengage tip akcapeco EcoModding Central 1 06-10-2008 10:07 PM
CL: Mechanics Special 94 Geo Metro Red For Sale 4 04-09-2008 01:48 PM
Video: Geo Metro Commercial! Peakster General Efficiency Discussion 5 12-13-2007 09:54 PM
