Old 12-25-2012, 08:54 PM   #95 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
For aero panels below the car you might still want to use Coroplast because its so much lighter than other stuff and holds up very el. Mine has about 50k miles on it now. I do recommend 1/16" or sometimes 1/8", by 1" aluminum bar stock for framing for Coroplast. It's too floppy all by itself for big panels, my opinion.
To fasten panels to framing I used 1/8" diam pop rivets with washers under the flared heads. If joining panels together use 1/16" or more bar stock on back side for the rivet to grab.
That said, the FRP sheets might work well. Just make sure they are not adding unneeded weight.
Coast long and prosper.
