Old 12-26-2012, 11:31 PM   #4 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
The two codes that showed up were engine coolant temperature sensor and "secondary air injection system". I replaced the ECTS earlier today and the driveability improved a lot. Strangely, replacing the ETCS made the CEL go off but it still revs high in neutral so I'm thinking I'll still pull the IACV off and clean it, or even replace it and see if that helps.
