Old 06-14-2008, 12:35 PM   #55 (permalink)
metroschultz
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Yes Sir, that metal case is the E.M. shield for the wiring and it needs to be grounded.(usually through the connector itself)
And grounds are never a bad thing.
I have found in the past when I have a ghost prob. that sometimes just adding a dedicated ground from the Eng to the trans to the frame to the puter to the bat seems to work. Not necessarily in that order.
Not sure exactly why, it just does.
Old trick from a coworker many years ago.
Hope that helps,
S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
