Rpms are screwy while moving the ecu uses speed and?? So it's only a set steady # at idle. And idle is supposed to be like 600rpm I think. Get an Exedy clutch kit they are the oem supplier. And 300 is a little steep unless it's a vx trans for sure. There is no way from markings to tell. Only big or small bearing and you need a small. I'm not sure if I would trust an eBay rebuild kit for a trans. eBay does have the clutch kit and they are real and like 100$ buy with a seller w good feedback. I pmed a guy bout a trans for you so. I'll let you know what I hear.
