Old 12-29-2012, 10:20 AM   #38 (permalink)
serialk11r
Originally Posted by TheIVJackal View Post
I need to take out my IACV and fix the the high cold idle on my car. It's about 200-rpms above where it should be, ~1,700. My question is, how much extra gas am I using by having a higher idle?
Hmmm are you sure it's the IACV? My car cold idled at 1700 yesterday briefly but I think it's because I did a bad splice on an O2 sensor heater circuit wire and the ECU is having the engine idle high in case there was a more serious driveability issue. At any rate, 1700, 1500 not a big difference I imagine, it's probably just a few hundredths of a gallon per hour more.
