Old 12-29-2012, 06:12 PM   #105 (permalink)
RatherDashing
Originally Posted by Rusty94cx View Post
Rpms are screwy while moving the ecu uses speed and?? So it's only a set steady # at idle. And idle is supposed to be like 600rpm I think. Get an Exedy clutch kit they are the oem supplier. And 300 is a little steep unless it's a vx trans for sure. There is no way from markings to tell. Only big or small bearing and you need a small. I'm not sure if I would trust an eBay rebuild kit for a trans. eBay does have the clutch kit and they are real and like 100$ buy with a seller w good feedback. I pmed a guy bout a trans for you so. I'll let you know what I hear.
That wud be helpful with the trans.where shud i buy the rebuild kit from? Shud i get one with synchros in it as well? And also i think my car might be idling funny cuz the idle screw was adjusted by previous owner.where is the stock position for the idle screw? I cant find anything bout it anywhere
