Old 12-31-2012, 01:51 PM   #11 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
pete c,
When you question whether it's worthwhile buying insulation, I'm not sure if you're referring to the valve cover or to hood insulation.
Anyway, if you think there's more return in insulating other areas, please do them on your car, and let us know how it works out.
The foam for the valve cover was $6 for the roll as I mentioned in the first post. What I did not write there is that I used most of the roll. I certainly could use the rest of the roll on this engine, it would only help. If doing an engine larger than my 1.6 liter Civic's, one would probably use the whole roll anyway.
I don't think this would be a "basic" mod, one of the first to be done on a car. But it makes a lot of sense for a car with already reduced fuel consumption and thus reduced heat generated. And definitely makes sense when using a block heater, in my humble opinion.
Coast long and prosper.
