Finally fitted 2 x 28s3p A123 OEM lithium 60ah modules into my HCH1 Civic instead of the puny nimh oem pack. I now have ~10kwh of capacity to play with using the manual IMA control documented on here.
A few bits to do yet to finish it off but getting there.
The write up is on IC forum.
HCH1 A123 60ah Pack Install - Insight Central: Honda Insight Forum
Check my You Tube Channel (retepsnikrep) for updates and videos.
Peter
