Old 01-11-2013, 11:05 AM   #199 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by a8ksh4 View Post
I definitely like the idea of building a small trailer as a sleeper.
Sorry, I wasn't suggesting a trailer in your case, just using that as example of people sleeping in something as small as your lowered shell. A few posts back you spoke of removing the foam after fiberglassing. I assume you mean the braces. Leaving the rest of the foam in place would make a very light and strong sandwich construction and provide lots of insulation too.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
